  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
hahaha... there was work to be done, i had to save the world, if you can understand that i have to use my super powers for good, then maybe we just can't be ....be ....oh god...i can't put on this act anymore i am with spiderman now!! i'm sorry i just wasn't going to work, it never was!! surely you can see it. *cut to close up with long sad stare into foggy lens* to be continuted
how was that!
^LOL copy of me n mels emails ..... god we are sooo bored ... but its funny just had to share.
but im not .... as i said ... why take him to court ... no witnesses .... my word against his .... and im a bit shaky on some of the details cos it just all happened to quickly.
Mel's ok .... like me - would liek to do something more interesting but put ups with it for the sake of an income.
im back guys
Niz i just spoke to my mate from REVS and this is what he had to say.
"the only people that have personal details pertaining to car regos are either
the police and the department of planning and infrastructure, revs only obtains
these details if the car is encumbered and even then we would need the engine
and chassis no.
tell your friend, the first thing she should do is go to the cops as a hit and run is
a serious offence, one that cannot be classed as a spent conviction, there is no
way she could lose a lawsuit against the hit and runner "
sorry i couldn't get the info you wanted :(
Originally posted by Nizmo
Whats the point? .... i have no witnesses ..... and even some of the events that took place im sketchy on ....... technically he shouldve hit me passengers door .... but he hit me face on .... full on ... how the hell that happened i dont know ......
you HAVE to do this.
do butts girlie. you HAVE to HAVE to do this.
today if possible. even if you ring them and let them know. then you can make a proper report at the cop shop later.
apart from anything, he could have made a counter claim that you crashed into him. witnesses or otherwise, if the nett damage to both cars exceeds $1500, then the driver which caused the accident can be liable for criminal charges.
therefore, you need to go and tell them everything you know. especially seeing as he did a ruinner.
PLUS, because he hit you, if you find that your car is more fuxxed than you think, you will need to have made a police report for any court proceedings OR EVEN INSURANCE CLAIMS.
takes 1 call - do it now. or I'll spank your bottom.
LOL .... i could enjoy that spankin tho Alex.
Ok well that cop shop in east perth ....u know the big one that handles all the infringements .... reckon i could do it there? do it in my lunchbreak tommorrow or sumthin.
we both left the scene of the crime ... couldnt very well stay in the middle of a busy intersection and battle it out could we but i parked by a side street and waited for him .... he didnt show .... so i went in further and got my car outta everyones way and then started calling everyone.
Sorry Revn .... i forgot to thank you for your time and trying for me *hugs*
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
    • I neglected to respond to this previously. Get it up to 100 psi, and then you'll be OK.
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
