  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
NIZ,
Same car as before "Sheep in wolf's Clothing" hehe
RevN,
Yeah, still in F&F clothes but will change soon, badge will go to
(still get people who dont know liners)
Strich,
Yeah saw your car but couldnt see you, would have waved.
Was buying White R33 from Autowrox, but didnt make it, so back to the old girl and make more power hehehe.
oh i spotted Judged on the way back from the Drift Training Day in Wanners about a month ago .... parked on the side of the road talking on ya mobile ....... wouldve waved but i was driving the ZX.
Lee,
what model commy?
Danny,
hehe. those must be the most talked about decals in the world. everyones a critic until you tramp it and spray molten rubber up their windscreen! :rolleyes:
race theme good. something that just says "this is what it's all about. this is what it's supposed to be"
now the impact wasnt that hard ..... i managed to brake completely and he just locked his up but sailed into me at a fairly low speed.
So i wasnt thrown about in the car too much .... neck etc all fine .... just sore muscles from gym :cool:
Then again if its going to cause a neck massage from some hot guy: Owwwwwwwwwww!!! :rolleyes:
yeah, dat be me, thinking that was weekend I was at Autowrox driving white GTR around the area and had pulled over (my old car) to talk on the phone (good boy I am) and bragging to everyone hehehe.
i ws going to on way home then remembered that the rego number was at home ..... so not much point.
And tonight i dont even have time to scratch my arse after work have to thrash shite outta Laser (with no petrol) get home n go down south.
no GTR and no GTR money makes alex something something...
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
