  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
HA! Forgot to add it wasnt' my car! (thank god!)
It was in my mates VT Commo..... and it was a head on collision with an old corrolla, coming around a blind bend :(
I broke the seatbelt at the amount of force it took when we stopped! we were doing like 50, and the other guy was doing like 80... then BANG!
the other car was a writeoff, the yobbodore is fine, but a little mashed!
Not really driver error, just you couldn't see around the blind bend.....
the road was single lane so that didn't help...
driver is VERY skilled, he's actually a mate of ours... it's just one of those "shit happens" things...
I've got some bruising from the seatbelt and a bit of a sore neck and raspy throat that tastes like airbag dust (still!) but other than that i'm fine....
Yeah, it was a VT..... meh....
I'm suprised it came off rather well.. still prolly around $10k damage tho!
Those Airbags are the stinkiest, worst things to have explode in your face... let me tell you!
On the way home I was a little freaked out at oncoming car's coming around bends in the road... *phew*
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
