  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
HA! Forgot to add it wasnt' my car! (thank god!)
It was in my mates VT Commo..... and it was a head on collision with an old corrolla, coming around a blind bend :(
I broke the seatbelt at the amount of force it took when we stopped! we were doing like 50, and the other guy was doing like 80... then BANG!
the other car was a writeoff, the yobbodore is fine, but a little mashed!
Not really driver error, just you couldn't see around the blind bend.....
the road was single lane so that didn't help...
driver is VERY skilled, he's actually a mate of ours... it's just one of those "shit happens" things...
I've got some bruising from the seatbelt and a bit of a sore neck and raspy throat that tastes like airbag dust (still!) but other than that i'm fine....
Yeah, it was a VT..... meh....
I'm suprised it came off rather well.. still prolly around $10k damage tho!
Those Airbags are the stinkiest, worst things to have explode in your face... let me tell you!
On the way home I was a little freaked out at oncoming car's coming around bends in the road... *phew*
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
