  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Sub yeah noticed a couple of extra but i still am naughty .... even in the Laser .... they be out for double demerits too ..... vultures!
LOL @ Lee ....... i'll see you down in Scarborough this weekend for your final test then :) ..... if you pass i'll buy you a 6 pack of VB :rofl:
Good to hear Ross!! :rofl: not much has been happening .... oh you werent around to hear some prick went thru red light and rearranged my front bar last week :) she's in the panel shop now getting fixed!
Bye Erin!!
Alan .... i got breath tested once - 2pm in the afternoon outside their cop station in Kalamunda .... what tha? nothing happens in Kalamunda .... especially at 2pm!
