  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Paul, Did you talk to Memphis about stickers ..... can i get .com ones slightly bigger?
You said there were hotplate ones but none of the long ones - which is the ones im mainly interested in.
Telling me your not much for sleeping in!! Dragging me out of bed at some ungodly hour on a long weekend and telling me to have a shower :)
I might as well ask - then i'll get exactly what i want :(
i blame the messenger!! :(
I used to be an early riser too but somebody got me into the bad habit of sleeping in til at least 10 on the weekends!
Paul dropped off the shirt but Danny wasnt there .... so u might wanna check he got the shirt.
    • Have you tried to start it with AFM unplugged? From memory with TPS closed and AFM unplugged an RB25 will start and idle (won't rev). This will tell you it's either AFM, AFM wiring, or tune. You also said Z32 ECU with Nistune?  Have you made all the necessary changes like the change of the ABS input on the pin the Z32 uses for TPS closed? Was the Z32 specifically setup for RB25 S1 or S2 from R33? There are differences between that need mods done on Z32 ECU. What's the part number on your Z32 ECU?
    • You've been so patiently waiting for your moment!  🤣 Haven't got enough time on the freeway. I did drive it up from Canberra but I have no idea how it did in this area.
    • Out of curiosity, how do you cover up the inspection hole? Surely it doesn't sit open like that, right? With grime and dirt coming in and oil going out?
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
