  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
thats ok ... wont be back to your place til after 7.
what do you wanna do about dinner ..... was going to grab some mince n stuff from home n make spaghetti bog ..... but mum used it last night to make guess what .............. spaghetti bog!!
    • I saw a car just like this stopping at Harvest for coffee this morning
    • Factory Dash Lamps...Half the speedo was dark...T10 3 Watt Park Lamps...T10 5 Watt Tachometer Chip/IC...Tach would randomly go crazy or stop, replacing  capacitors and re-soldering the chip would work for a week or so but it would always fail again...AN8352UBK (Buy on ebay AU) Heater/Air Con Control Button Lamps...Grain of Wheat Bulb 12V...Tried LED's they fail after a month or so(even with current limiting resistors)
    • Hi, need help on wiring i swap motor from rb25de neo to S1 rb25det. Is it possible i can still use the de neo loom or do i need the s1 loom? Can i add extra wiring to add wastegate soleniod and iat sensor? Can i use injector and coils on same loom as i running bosch injectors and vag coils? I bought nz wiring trigger kit for neo, can i use that on s1 motor? What else do i need to do to work everything right?
    • Tried some stainless allen head bolts I had laying around, they stuck out like dog balls, so I went to Bunnings and got some black coated jobbies, which I like alot more.....basically OEM....LOL I'll RTV it up this week sometime ready for MX5 Mania to do their thing
    • Good tips, will get on those tomorrow. When doing the maintenance I did move a few of those connectors around, and things that are old tend to not like moving around. (Like me).
