  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Erica .... applied for a far better job ..... but i had the interview the day of my car crash ..... so i wasnt my usual self and im not feeling very confident about how i did ..... but still want to be put outta my misery and know!!
haha ur funny paul!
Good luck with your job Lauren... fingers crossed for you girl!
Yeah I hate playing the waiting game too..
I bought lots of goodies for my car over the last week, boost controller, apexi safc, auto metre boost gauge, auto metre air/flow ratio gauge and the pod thingo's for it..
they are gona get put in when we get back from vic...
Lucky you Erica :) yeah reason for new job ..... pay goes up = new goodies for car!! At the moment im locked in a long battle just to get a veilside rear wing put on :P long story!!
Yeah trip home was a prick ....... flying next time. It was a good experience tho. :) and i wouldnt rule out doing it again ...... but not for a while!
Yeah you poor things, it would have been a real icky long drive...
my car is faster than johns at the moment... his engine is out.. but once its in i can kiss that title good bye! haha
Veilside wing would be tuff lauren.. i hope you get this job, lets see how you go, post up when you know the verdict.
    • You need one of those automated sprays that puffs a nice small every 15 minutes in their room. Except swap the nice smell for chloroform...
    • Don't step down power supply size, maintain it the whole way. It's how I'd do it. OR, Id have one feed, with one joint that splits out to six smaller gauge wires that go to each coil. I wouldn't add joins like stepping from 12 to 16, at the first two coils, as if you try to continue that fashion, each joint will introduce a voltage drop. In theory, earths should be the same size as power feeds, however in this case the main power needs to be bigger due to the average size current. So the next question is, how much current do these coils actually need?
    • I think Murray is onto it. It's sounding like either it's a soft block, not long enough block, OR if you're chasing waves, you're going in the direction of the waves, instead of across them. Rotate your sanding pattern by 45 degrees is something to try. You said you're going in an X, so now instead, from the same perspective, do a "t" instead.   If you're not able to have the block sit on top of two high points, and not touch the low point between them, you'll never get it flat.
    • Hi, i’m making Vag coil loom for rb25det, can anyone confirm the wire guage i’m using for power supply in diagram is enough for supply not too small for loom? For earth do i need to follow the same procedure or i can use only 16awg wire for all coil and their connecting wire following to the plug?
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
