Yeh ridiculous huh. I would have told em to gos hove it and test me in 10mins after i skull 4ltrs of water. the 3 points doubled to 6
When he callled me he was all quiet and said he couldnt talk cause there was a cop watching him. if it was me i would have said "ahh can u come pick me up?, some gayboy busted me for being .001 over the limit and he loving his power trip. hes standing right here eyeing off my ass. Ill be on the side of the road with the bunch of drag queens and the gay ass disco lights."
whats he gonna do bust u again?
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
nah i was really friendly to cops ..... one just spent his whole time in the booze bus sitting and chatting to me. Even when he asked me how many points i had and i said "only three" and he raised his eyebrow at me and i go "well i drive a fast car ok?" and he laughed. Cops i got were pretty down to earth n cool and were doing everything possible to get me off the hook and obviously it worked. Actually had a good time in the booze bus LOL :) We were discussing how it would be a cool vehicle to travel around australia in :P
Paul, not likely ...... prefer doing motorkhanas. Less stress on car ...... more interesting.
Paul - its not my tits that got me off hun .... you boys just get this aggressive front on everytime you encounter a cop and instantly start rattling off why they are wrong and you are right ........ you all take the wrong approach and you all get stung.
First thing i always do is admit i was wrong .... you give them their ego trip .... and then they decide your actually a decent person and worth helping.
Nahh hell just take it.
Id prolly be the same in that situation. He doesnt know how to hide his emotions properly and show respect like we do. Cops know hes an easy target and go for it. Plus on double demerits and all, the CO would have been out for blood so no tolerance at all. Still, hes got 6 points left. he was drving the crappy corrolla too, u know the one Paul, which has bald tyres and a busted contolr arm or steering column from when he anile da curb last month, its also missing a headlight now.
yeah ive been done on a double demerit weekend before 6 points ...... let me off with a warning ..... so they cant be that much out for blood .... but it wasnt a traffic cop either.
Paul .... my tits aint that huge hun ..... they've never got me anywhere before and i doubt they are miracously going to start opening doors for me now!
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
