  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeah they have full frontal repeats on the Comedy Channel ...... great for reliving all those Poida moments!!
Might have to take that piece of advice on the Laser Boosty. Hey the Laser will not go into reverse first thing in the morning ..... werd .... you have to put it in first .... then try reverse.
Originally posted by dan_the_man
hahah theres some fella near Darlington with a Bright green VN commodore with the number plates POIDA
all his family park their holdens lined up on the front lawn...
damn hill billys
Seen that car.
Unfortunately so does my family...... it was even worse when Ben had his Marloo ute ..... trev family :( ..... least my family doesnt own a single flanelette shirt.
Actually maybe thats what i should by dad for xmas ..... here dad you've got every piece of HSV merchandise ever made apart from a flanellette shirt!
    • Yea I could, but it is amusing how shit a stock seat and belt are
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
