  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by 33Spec2
course is god damn boring rite now! im doing the most boring and hard unit so i dont have to do it later on heaps of assignments which i always leave till the nite b4!:(
hmmmmm i need a job in car design!
He he I need a job full stop.....
Too much exoerience is bad in this town. Nobody wants to pay you. And the rest are afraid of competition.....litle bit of comp is no bad ha.....
What units are you taking?
Ahhhh those student days.....the best days of my life.........
aaaaaaaaaaaaaaaaa adult hood......
WMD...hehehehe.....my turbo.....might be forced into exile.......hehehehe.....
I was afraid it would be a problem....
I hear of engineers doing things to cars before .....and this was the issue with my car......the guy I got it off wirked for the navy and wanted to prove himself..... 265hp out of stock turbo.....dyno sheet ...in singapore now.......I emailed him but doesn't reply back......I am worried.....he killed it before me...........Alvaro knows how the car drove when I got it.....it was a rocket, now its a ...I cant say it.....
Paul, I have designed a killer bodykit.....
I am producing it now........on the mould of the GTSTm spec.......the mounts I need to get of a second hand model.....
That is why I am looking.......
Will have to show you the design .........
It's secret.......some guys wanted 5k to produce it in Sdney......I said I will do it myself.........ha :(
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
