  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
im here Angel :)
Grandparents are over .... hiding in study with a glass of wine - haha i had to drive back from the winery (them & my folks went out for their wedding anniversary) .....and my mum was pissed sitting in passenger side of Clubby ... grandparents & dad in the back anyway htis Holden Statesman tries to take me on and mum says it was ok for me to drag :) my grandparents almost had a heartattack!! ...... i won :D but hell takes a while for the Clubby to get the power down!! so wish had my car back :uh-huh:
working on a sunday???
Phuck that!!!!
Counting down the days til my car comes back (if i only knew how many days i had left to go!!) im getting so excited ..... getting new spoiler ..... getting EBC ..... getting Gauges ..... eventually getting chequer plate ....... my car wont recognise itself :)
neither is my dad *insert whiny voice here* "but it'll be noisy and horrible ....Lyn you really dont want it ..." ... my car .... i do want it .... whether you get me a price or not its going into my car :D
Something special? hope it looks special :) yeah everyones rushing round for PAS ..... only two weeks now ..... you coming to see?
you get a day off during week to compensate? ..... not so bad then :)
dont know whether im doing the right thing changing GTR rear spoiler to veilside tho ...... i have to wonder ...... oh well just sick of looking like a clone and i guess still have GTR spoiler if i dont like veilside.
haha i'll be the tall blonde in the white Skylinesaust top and the denim shorts ...... well its me in avatar anyway so come n say hi ..... ive been recruited as one of the "promo girls" so i'll be there all day :D .... haha ive told or my mates ot come say hi .... keep me occupied :)
wonder why Nissans brought out that maroon red ...... Skylines resprayed in blood red looks ten times better ..... they are so nice :)
Browsing carpoint ........ get some nice cars on there ...... give me ideas.
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
