  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Some 50ish lady all "dolled up" in a crappy old intergra pulls up next to me at the lights with her - i think - mum next to her, her mum was really old. The 50ish lady goes "hey, u drove like a dickhead back there" her mum was looking embarrassed by it all so I replied "calm down lady ur embarrassing ur little sister"
