  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
:slap: Boosty ..... becareful or you'll get a knitting needle up ya butt. Already for ya run tonight?
Cool Richie - anything you can say??
Hey Dan - you know you love my links ;) ..... unfortunately cant send it to Liz cos she's not allowed on the net at work :)
Heheh thought ud like that one. Yep shes as good as shes gonna get without me sepnding money i dont have on it. Dont expect to be too impressed it is fwd after all. I just wanna see what it can do for my own info.
Not sure if im comming tonight ..... i dont really trust taking the Laser outta the metro area and by the time i actually get the Laser to kwinana its going to be over .... soooo slow.
But be nice to see everybody .......
Ok Richie :) .... nice one dump pipe :) i should get my car back hopefully sometime next week
Tried to chase a guy in a Skyline today but i was in the Laser so pretty unsuccessful ;)
Boosty .... trust me you'll do fine .... haha i dont dare take car down to drags .... i know it'll have a disappointing time!
    • I see what you mean on that last paragraph and makes sense. I am leaning towards because I made the repair/filler area large that I didn't use a long enough block. Will minimise the area and let you's know how I go. This is random but I noticed when I put epoxy primer it felt flat but that's just temporary.
    • Tried to repair with filler only. The block is a foam block but quite hard and I put a velcro on it for sandpaper, the hook and loop system. It's not one of those super soft ones that just follow the panel. Similar to a dura block.
    • You need one of those automated sprays that puffs a nice small every 15 minutes in their room. Except swap the nice smell for chloroform...
    • Don't step down power supply size, maintain it the whole way. It's how I'd do it. OR, Id have one feed, with one joint that splits out to six smaller gauge wires that go to each coil. I wouldn't add joins like stepping from 12 to 16, at the first two coils, as if you try to continue that fashion, each joint will introduce a voltage drop. In theory, earths should be the same size as power feeds, however in this case the main power needs to be bigger due to the average size current. So the next question is, how much current do these coils actually need?
    • I think Murray is onto it. It's sounding like either it's a soft block, not long enough block, OR if you're chasing waves, you're going in the direction of the waves, instead of across them. Rotate your sanding pattern by 45 degrees is something to try. You said you're going in an X, so now instead, from the same perspective, do a "t" instead.   If you're not able to have the block sit on top of two high points, and not touch the low point between them, you'll never get it flat.
