  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Nizmo, fair enough.
Your not planning on replacing the back speakers with those splits, are you? What have you got in the front? Its just that back speakers are usually less than useful, and if your current ones are fudged (like mine are) just disconnect them. Rear stage is distracting to the listen to, better off having good speakers in the front and nothing in the back.
(don't mind me, i used to be a car audio head)
haha nah its cool .... ive got Kenwoods in front .... work really well. Rear has been faded out for now - but i would like all the speakers to work ..... i also have to have a decent stereo system in my car!!
Actually all my stereo setting were done A1 by a mate of mine but the battery went back and i cant seem to set it back to sound as good as he had it :D
GTS-t VSPEC, MB Quart and low budgets just don't mix :D
I had a pair of MB's in my last car and I wasn't a big fan of the tweeters. Thankfully, the thevies only took the tweets and left me the mid bass. When I find a worthy tweeter I'll put them back in my car.
hehe yeah mine sounds like a bit of a bogans car when it gets turned up ...... lotsa bass haha. Joe reckons it feels like the seats are giving him a back massage they vibrate that bad ....... but it hasnt been like that since the Battery went flat so once the rear speakers n splits get put in i'll play around with it.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
