  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by nc311hiver
is everyone in this con-vo from Perth?? I'm not, obviously, but, i'll be in Oz sometime soon. Dont bash @ me for not being from Perth but posting anyway.
xloveX
%Amanda%
Wow , our reputation for whoring is spreading far and wide.
America even:D
Are you coming to Perth or the East and why are you posting on a Skyline forum:) ?
Cheers
Ken
