  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeah my friend goes to me "Is that what i think it is" .... and i go "Yeah its blood and quite a lot of it" and we are looking around for the source then the bouncer comes across and sees it and expects us to know where it came from...... think that was the stage dancing night.
Wilzlee yep been to Belmont Racecourse many times haha its awesome ..... hasnt been quite the same since they stopped it :P Still i have been talked into going to the next Ministry of Sound at the end of this month i wasnt gonig to go but my friend got down and pleaded so i agreed cos im a good friend :)
Originally posted by sub
aerograce!!!! so wot if its a FWD??? do u wanna take ur car down to race wiv one of our FWD?? ppl who push a gal's car is worse than a L-Plater.... learn how to drive like a man b4 u tok any crap!!!!!
what are you one about??? :confused:
the sig wasn't aimed at you or anyone of your friends.....or anyone i know.....just some random comment....what are you worked up about? jeez....
who did i try to push anyway??
nitezz people!!! have to go now...hunt for something to eat.. a hungry man is an angry man!!! hehehee..... let me know whens the day when u guys gonna pput ur cars in so i can come pass u all the lightss n all....... hope can make SAU stand out a little more.... BYE!!!!!!!!!!!!!!!!!!!!
By this Saturday for the Mt Brown Hillclimb ( Enjo SES rd 8 ).
Has whats his name burned the CD yet or will I have to buy more tapes??
Am off Wed and will be in town for a while if that helps.
Cheers
Ken
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
