  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
you guys bombed out on your last photocomp haha
yeah all my Cuz's are in Mandurah the only time i get to see them is SAU cruise then its like a family reunion :D all i got to do now is get Kirsty a SAU guy and i'll see her occasionally too ;)
