  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
haha u didnt do the leederville cage thing did ya .... haha we got Matty doing the Sprinkler in there one time ... he does it so well .... just pissing ourselves laughing!!
Havent been to Leedy in ages .... used to go there a lot. Get pissed then go across the road for a kabab to sober up.
Denver i nearly fell off the stage at metros city trying to get off it haha. Now theres a bit of a steep drop!!
Niz, You love stage dancing:p
Danver, A few people are worried about results being fudged with correction factors, just wanted to be able to reassure them that the readings would be accurate.
Dan, Don't worry, I'll treat it like my first born child;)
the results can't be fudged with correction, and i wish certain workshop people would stop telling people it can be fudged, ivan isn't going to be fudging anyones results no matter who it is, he has a business to uphold, not cater to the likes of people wanting to cheat, it will be a fair and level comp i can assure you
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
