  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Danny, Yeah, will still need the barrier tape. Also bring the bonnet holder sticks you have.
I know you need the setup time, so do I :shake:
Niz, Ok:D
Paully,
No probs with the Barrier Tape, do you have some type of pole arrangment for the cars??? I will bring two Bonnet poles for ya after I have sorted out my bonnet, should be no hassels there. We will need lots of 100mph tape to hold things down and it is just good to have. Go to spoiler shop to get some yukky front bar off my car and put mine back on. :( Today yeah.
NEED SETUP TIME!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Niz,
Are you girlies wearing long boots, GF wants to know so as to look close to what you and kyles are wearing??
:jump:
nah i have boots in the wardrobe but they make me look like a phucking giant!
Ive got white strappy shoes, short blue demin skirt/shorts depending on my mood and the PAS top. Kyles is similar shes got strappy lil heels, short blue demin skirt and the PAS top :(
aidwin what happened :grouphug: ..... your cars getting fixed - should be done soon. As for relationship thats sad :( oh well think of all the lovely lasses your going to see at Autosalon ..... we'll have so much fun!!
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
