  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Man i cant take it, ive used a nokia all my life and now i got this god damn crazy backward Motorola with buttons that a damn protos couldnt push.
Ive been bitching at teh phone company all morn but they dont seem to sympathetic. Cmon its not that bad, its brad new ffs. Somehas to have an 8310 or something they wanna swap
