  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
:) @ Liz ...... we should start new careers in telemarketing ;) couple of bottles of wine on our desks and we'll sell ice to eskimos!
Richie - auto salon ..... thank god its over ..... *trundles off to get another icey pole, bag of chips and a block of chocolate*
