  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
shit, sorry paully. forgot about that on sunday.....
will come and get them this weekend?
or if you need tha cash this evening?
btw - lamination was about 10 squids - so is it cool if I just give you $20 for the tee?
aidwin - schweeet! will you ride me?
I mean, take me for a spin?
bam, now everyone will be fasta than mee!! :D
Al, Yeah, they want to get 1000hp with a 200hp shot of NOS, but they will have to run CDI before that can do that, it's tuned for about 500hp on the street.
I'm running the 431hp map at the moment, but will get Steve to swap it over today.
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
