  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
aidwin - how much do you want for the drivers seat? seriously?
heya baminator.
dan - optus?
I like optus, but their plans such. **** paying $400 for a nokia - I'll go up the road to 3 and get one that sings, dances, takes ammetuer porn video, photos and brushes my teeth for me.
got any with free dvds? :bahaha:
