  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Killer movie "KILL BILL"
Ohhhh shit still recovering.....
so much blood.......................
Kick arse direction.......
Awesome bikes and katana swards.....
And one ZX300......he he he
They needed a godzila in that movie....
ahhhhhhhhhhhhhhh recovery will be hard.......shit this movie was made for 2 instalements......
still thinking about heads cut off......
shit I feel sick.........
Its not the blood or cut off body parts....
Its the music and art direction sith photography tied together that is such a unity and harmony in such a kill bill slaughter house.....feels normal to cut something offffffffffff.........
gona go and cut some bstake for tomorrow........
shit
ok you can see I am very taken by this movie.......
and the cartoon was the best of the best and worst of the horror......
ahhhhhhhhhhh
big AL recomends this movie!!!
I want the jun/akira supra
mmm 1500ps and twin t88's
when koyama was here he was elling us they'd just put the 88's on, and had to make a new bonnet as it wouldn't shut anymore with them there..
psycho's one of his funniest quotes about that car goes along the lines of 'i select 6th gear and get very very much wheel spin'
now thats a race car!
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
