  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Killer movie "KILL BILL"
Ohhhh shit still recovering.....
so much blood.......................
Kick arse direction.......
Awesome bikes and katana swards.....
And one ZX300......he he he
They needed a godzila in that movie....
ahhhhhhhhhhhhhhh recovery will be hard.......shit this movie was made for 2 instalements......
still thinking about heads cut off......
shit I feel sick.........
Its not the blood or cut off body parts....
Its the music and art direction sith photography tied together that is such a unity and harmony in such a kill bill slaughter house.....feels normal to cut something offffffffffff.........
gona go and cut some bstake for tomorrow........
shit
ok you can see I am very taken by this movie.......
and the cartoon was the best of the best and worst of the horror......
ahhhhhhhhhhh
big AL recomends this movie!!!
I want the jun/akira supra
mmm 1500ps and twin t88's
when koyama was here he was elling us they'd just put the 88's on, and had to make a new bonnet as it wouldn't shut anymore with them there..
psycho's one of his funniest quotes about that car goes along the lines of 'i select 6th gear and get very very much wheel spin'
now thats a race car!
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
