that was the first one?
First one i went ot was at Metros about three years ago and they decorated Metros up more .... bigger crowd ..... even opened up this outside bit i never knew existed put a tent up outside with heatlamps and cushions etc. haha Me n Mel were reminicing about the bus trip between Metros n Globe the first one we went to ... i was freaking out and all she can remember is sitting next to a pot smoking bundeburg rum bear haha funny.
And Belmont Park was the greatest of the lot!!
Never been to one a Belvoir tho.
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
haha it was quite ironic cos i was brought up religous and they used to hold big church assemblies at Belmont Park ........ 10 years later back at Belmont doing everything i was taught at church not do :P
haha yeah Aidwin was wathing this chick at Belmont who couldnt walk two of her guy friends had to carry her ...... and i went to Mel "NEVER let me get like that!" Some people just go to crazy and it goes from fun to dangerous.
next for paul is sitting on his arse whoring.
hehe Zombie Dan .... Melbourne Cup at Ascot was the funniest i have ever been like that ..... i drank so much too ..... thank god for sunglasses cos i bumped into so many people i knew that day and it took me about half an hour to recognise them :P
    • Its also worth mentioning that 30 years after it left the factory and god knows how many missed oil changes since, there is every possibility that one or more lifters are ticking because they are sticky/gummed up. To resolve that you need to pull the cams then pull each lifter, disassemble, clean, reassemble, soak in oil and re-install, and they should come up good as new.
    • What air filter are you running? Is it a panel filter in the stock air box, or a pod filter? Is the air filter the type that is oiled?   If you unplug the IACV, what rpm does the engine idle at?
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
