yeah well i was trying the mind over matter approach paul but you just shot that idea down ;) haha ..... yeah i know ..... parents huge minus.... lack of freedom minus ...... free rent, free internet, heated pool and spa and pets allowed is a huge plus tho ....... its a lose lose situation stay or go but i think i'll just save and start buying bits n pieces and get myself organised ;)
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Morning yall. Not a good 1 though.
So im lying in bed last nite and i hear a car alarm go off. I figure since the4 parents have friends around its gonna be one of them drunkenly stuffing up and making theirs go off.
I get up in the morning and hit the immobiliser when the key is in theon position as u usually do. The engine cranks over but it wont fire :confused: i look at the little batt, parkbrake lights etc and they are all off. The imobiliser is clicking on and off indicators flashing but no dice. I keep cranking it like the moron i am then get out, the fuse in the immobiliser is fine. I disconnect the batt and push the brake for a bit which only reset my clock and didnt do much else.
Any ideas cause i hate paying sparkys
i want pillar mount .... you know the one that fits on the pillar in nice casing ...... i dont want this huge dial sticking out in the middle of god knows where ...... one like yours paul.
But also saying that i dont want to spend a ridiculous amount on a phucking gauge!
Damn Boosty!! ;)
Paul no rush - might as well leave it til i get the veilside on and the car is once again fulltime mine!! and no i havent seriously started job hunting yet.
Aidiwn ..... you need intercooler etc to safely crank up the Boost .... which i dont have .......yet ;)
    • Also build this EH ute with 370z motor and gearbox with a couple of turbos just for fun.
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
    • I just stack 2 pieces of 200x50 timber on top of each other. Total length about 900mm, with the top one being a little shorter and both having a 45° angle cut on them to make the front edge a bit of a ramp. Put these in front of each front wheel, drive up on them, throw the trolley jack under. Takes 1 minute. Scissor jacks can eat a bowl of dicks. I never use on under my car unless desperate.
