  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
dan - well. done...
I wouldnt mind having 30 more hp. especially with the lighter fly :(
hey tom.
dan - are you just running a bleeder at the moment?
niz - your arse is too nice to put a big wing on......but if it were grey and dumpy......
paul, it's mean to call the horse the horse.
but not unjustified. :bwhaha:
