  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
dan - stick 'em all over your car....Rice rice rice !!!! and custom make another sticker " what are you looking at?" hahahaha :)
paul - yea, met him 2 times... :D strange thogh, he like long pants over here in this humid warm weather... :D
niz - 20 minutes? luck you......on strike again? wahhhhhh
Open the bonnet the other nite cause i smell fuel :confused: lo and behold one of the injector lines is spraying fuel eveywhere. Not just a trickle either it took me 1/4 tank to get from perth to home on south st. Was damn worried it might explode so got it towed next morn back to the shop.
O o and after the AGM on sun gradenko was running late for an appt so he let me take his car home to do some stuff i had to do. Im kinda half going this semi worked civic and i come up over a hill to see a speed camera, hit the brakes and check the speedo, 60kmhr, look back up and it flashes at me. Dammit. Stoopid civic getting me all rilled up :)
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
