  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
dan - stick 'em all over your car....Rice rice rice !!!! and custom make another sticker " what are you looking at?" hahahaha :)
paul - yea, met him 2 times... :D strange thogh, he like long pants over here in this humid warm weather... :D
niz - 20 minutes? luck you......on strike again? wahhhhhh
Open the bonnet the other nite cause i smell fuel :confused: lo and behold one of the injector lines is spraying fuel eveywhere. Not just a trickle either it took me 1/4 tank to get from perth to home on south st. Was damn worried it might explode so got it towed next morn back to the shop.
O o and after the AGM on sun gradenko was running late for an appt so he let me take his car home to do some stuff i had to do. Im kinda half going this semi worked civic and i come up over a hill to see a speed camera, hit the brakes and check the speedo, 60kmhr, look back up and it flashes at me. Dammit. Stoopid civic getting me all rilled up :)
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
