  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
fane - I love that nizmo bar.
would suit the look I'm trying to acheive to a Tee!
niz - 280 would be nice. 400 would be nicer!
paul - next week some time?
Aidwin - Xspeed are a ripoff. I could do it myself, but for this stupid warranty, I need someone else to do it.
I payed Suma to do it last time - it was reasonable, but it's too far away from where I live now.
