  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeah i probably wont actually get the SAFC II installed and tuned til the FMIC goes in ;) Do it all at once!! :)
Looks like all my friends are getting "tightarse Xmas" this year ......*better start swiping some stationary before i leave today* Mum ..... here have a pair of scissors for Xmas .... and Dad heres a stapler ..... Mel you can have a highlighter :)
mexr .... you religous ... tell me to mind my own business if you like ... its just most of my family of JW's and dont celebrate it either ... so really i only have to buy for mum n dad. :)
Fane .... sounds serious :) ... you going to use it for track work?
you can still tune your engine much better with an safc mex.... :)
i can see it helping heaps because the NA relies on good tuning so much.... all your Air/Fuel mixtures can be perfect...tuned for all your mods like exhaust and pod and shit.... as you get more you can forward the timing etc etc.... :) i can see it helping...
haha going to buy a big arse turbo Fane? Nah well mines auto so i cant have over 300rwhp anyway without going and replacing transmission with a hoity toity jap one .... which really aint worth it .... i just want a reasonably quick fun car .... but i just couldnt spend a huge amount of money on it - it would seriously make me cry the day you go to sell it and you've spent $10K in mods and only get $9k for the car haha :)
nah i wanna buy a play toy and make my GTST daily driver .... i so want an ferrari red R32 GTR .... oh yeaaaah!
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
