  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
my second excursion in the chair.. the 1st one took 45 mins cause it was on it's side.. the other two on this second excursion were heaps quicker.. which was all good cause i don't think i could have handled it otherwise...
hehe I went even further and got put to sleep for mine :P
Half my problem is that I dont know exactly what I need.... I just know its time to replace my worn out items so I may as well put on a complete new upgraded set of stoppers on my car...
Yeh been there, u get gas too?
Man ure teeth are coming in late, ure 4 years my senior and mine came through like 4 years ago.
How the sound of the cracking and snaping of stuff when ure teeth get pulled man its harsh, ill never forget that.
I have spent like a total of 200hrs in the chair due to my two front teeth being fake, braces and various other fun procedures.
me gettin some dba slotted rotors but i have to wait for the machining run over east to be finished cause there's none in stock for r33's.. should land in perth by the 18th...
is $560 cheap for a front pair?
I think ure allowed 6 doses a day. but u can also take 6 doses of nurofen a day cause its not using paracetamol. So thats 1 tablet an hour 24hrs a day. oooohhh yeh, take me to cloud nine baby.
Dont forget ure savacol and warm salty water.
nah - no gas... almost passed out yesterday after he ripped the two out tho... i don't think i'll be forgetting it in a hurry either... man - sounds like dentists have done a number on you! I'd rather do almost anything than goto a dentist...
Ahh u get used to it after a while. In year 8 i went to the dentist once a week every week for like a year. ahh good ol root canal.
My two front teeth are screwed into my jawbone, so they took a bit of work.
    • I refer you to this thread on PF, by someone who knows what he's doing. Paints a good picture of the humble AD09.
    • Ha, I've never pressed the X in all these years incase it removed the notification for all Admins
    • I don't know, I've never done it that way, but 1. While it is an interference engine, there is still clearance between the valves and the piston at all points in the regular timing cycle 2. There is not a lot of distance before you can't catch the top of the valve stem any more I don't know if 2 is greater or less than 1. But 3. If it doesn't work out you are f**ked, engine is coming out to disassemble so it is a big bet.
    • Semi slicks are horrible for road use, just use a high performance road tyre unless you really need the maximum grip. Noisy, unpredictable (amazing, until they are not), expensive due to very high wear and not good in cold and particular wet. And yes, it is a thing to store cars on stands instead of tyres if you know they are going to be parked up long term.....but who ever realises that a short park is going to stretch into years before it is out again!
    • I know in Australia you'll definitely get above 30c. Parked in the shade in Summer you'll be above that. 😛 But in cooler climates, you might get that warm driving on the highway for a bit, but you'd never get to full heat temp. I'll try and find some of my historical tyre temps between Aus summer and winter (be aware immin the warmer area of Aus too.)
