  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
i was pretty lucky but when i moved out of home, i had nothing but clothes cos mum wouldnt let me take my bed or anything, I furnished and equipt the kitchen for about $300
Of course the stuff was shit, and discusiting.. but ive replaced alot of my old for new if a short amount of time. if you work for it you can do it :D I should have my agc loan paied off before i start uni.. and there is $2000 left on it.
