  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
I want this car
1989 Twin Turbo Callaway Aerobody Corvette #10
Callaway Twin Turbo Engine
Twin Garrett turbochargers with integral wastegates
Twin front mounted oversized ram-air Spearco charge air coolers
Special dual inlet air induction system with high flow K&N air filters
Special 3" dia. Free flow Turbo exhaust system with crossover for export
Stainless steel 3" diameter inlet 5" can Supertrapp mufflers
Heavy duty cooling system with aluminium Griffin racing radiator
Alfa-laval 10 plate oil to water engine oil cooler
Accel/dfi engine management system with Callaway calibration
Racing Electronic Services accel/DFI-GM E.C.U. adaptor system
Bosch injectors, 51.24 PSI at 60 lbs of fuel pressure
Callaway prototype hood with charge-cooler air extractor openings
Callaway prototype Ram-Air high flow capacity nose
Callaway carbon fiber "twist" air inlet
Callaway carbon fiber charge cooler extractor ducts
L-98 engine block, 4 bolt main caps, splayed-bolt style
Michigan engine bearings
Forged gas nitrided crankshaft, 60Rc journal hardness
Proprietary cosworth forged pistons, .006" O/S
Plasma moly ring package
Carillo connecting rods, 5.7 centers, matched and balanced
Experimental short runner fuel injection inlet manifold
High volume oil pump
Hydraulic roller lifters
Specially hardened distributor drive gear
Dry sump pump for turbo oil scavenge
Oversize stainless steel inlet (2.020) and exhaust (1.600) valves
Corvette L-98 cylinder heads killer ports, gas flowed and decked
Dymag 17.0 X 9.5" wheels
Goodyear P275/40 zr 17 tires
Callaway fuel and manufacturer's plaques
Refinish intake manifold/tuned port injection with black wrinkle finish
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
    • I believe @Duncan has given it a crack at Mt Buller before (in actual race conditions)
    • All my Polish car culture insight comes from watching Nightride. So I half expect this to get 1UZ swapped eventually?! Are you going to drive it in winter? I'm always curious how ATTESA would hold up in the snow. There isn't that much opportunity to try it in Australia.
    • My steering lock unit on my Infiniti G37 has failed. The car is a local 2012 Infiniti G37 (Q60 ) I need to replace the unit My local mechanic said i need to buy a complete steering wheel assembly. Does anybody no any mechanics in Gold Coast or Brisbane who can fix this issue or where i can buy just the Steering lock control unit. Thanks
