  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
I want this car
1989 Twin Turbo Callaway Aerobody Corvette #10
Callaway Twin Turbo Engine
Twin Garrett turbochargers with integral wastegates
Twin front mounted oversized ram-air Spearco charge air coolers
Special dual inlet air induction system with high flow K&N air filters
Special 3" dia. Free flow Turbo exhaust system with crossover for export
Stainless steel 3" diameter inlet 5" can Supertrapp mufflers
Heavy duty cooling system with aluminium Griffin racing radiator
Alfa-laval 10 plate oil to water engine oil cooler
Accel/dfi engine management system with Callaway calibration
Racing Electronic Services accel/DFI-GM E.C.U. adaptor system
Bosch injectors, 51.24 PSI at 60 lbs of fuel pressure
Callaway prototype hood with charge-cooler air extractor openings
Callaway prototype Ram-Air high flow capacity nose
Callaway carbon fiber "twist" air inlet
Callaway carbon fiber charge cooler extractor ducts
L-98 engine block, 4 bolt main caps, splayed-bolt style
Michigan engine bearings
Forged gas nitrided crankshaft, 60Rc journal hardness
Proprietary cosworth forged pistons, .006" O/S
Plasma moly ring package
Carillo connecting rods, 5.7 centers, matched and balanced
Experimental short runner fuel injection inlet manifold
High volume oil pump
Hydraulic roller lifters
Specially hardened distributor drive gear
Dry sump pump for turbo oil scavenge
Oversize stainless steel inlet (2.020) and exhaust (1.600) valves
Corvette L-98 cylinder heads killer ports, gas flowed and decked
Dymag 17.0 X 9.5" wheels
Goodyear P275/40 zr 17 tires
Callaway fuel and manufacturer's plaques
Refinish intake manifold/tuned port injection with black wrinkle finish
    • FWIW, I've aerated oil, and cams snapped. You can figure out the rest 🥲
    • Depending on the hose, sometimes engine out is the easiest option
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
