haha nah shes not here but i just woke up in a daze and still dreaming hehehe :D
Pauls not welcome in my house he scares me and plus he beat me in mega golf so im cut :)
Yes she is a lot of old blokes fantasies :)
pwptpf is ok until he starts caressing you...
Cheers
Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
and also congrats Ken :D
*me does thumbs up sign*
Thanks Tom .
Next years SES will be for fun only with a stupidly tuned R33 GTS-T.
*Hmmm gts-tken doesn't quite sound the same does it??
Cheers
GTS-Tken
Ken i really think you should stop right there too
especially if paul has been touching you..
im about to sleep, don't need that mental image!
Yea , best you sleep..
Jules said you were a bit prudish while I was there with her.
* ken wakes up from dream*
Cheers
Ken :Oops:
j/k denver , was just kidding
I dunno if im doing the SES next yr, or what in, wanna do it tho..
Denver , at the end of the day , just DO it.
Before CAMS puts the * rollcage, harness, firebomb,triangle thing* into the equation.
While the chance to go stupidly fast on highly dangerous venues with CAMS insurance is offered, take it....
Next year I ain't going fast, just VEEEEERRRYYYY sideways :D
Cheers
Ken
id like to do SES in the hr30 but its alot of time money and skill i havnt got yet in an underprepaired car.
BULLSHIT!!@!!!!
There is no such thing as an underprepared car.
Classic is Neil Gerace in the brown bomber.POS old Toyota Corona RT118 that he drives to wherever, thrashes crap out of and drives home.
Gets no where , has a hell god time and all he pays is fuel and entry ( bout 80bucks)
Cheers
Ken
yeah but i wouldnt want to do a half assed job in a car i havnt even driven yet -- rather wait a while learn which i can do get some nice brakes on it then push it in comps :D
Tom , at the end of the day , there is only one winner.
If you aren't experienced/have a good car/rich/nutter/allthe previous , then you won't get anywhere...
SOWHAT!!!!!!?????
Go there , enjoy yourself, learn , have fun, ask questions, try it.
So many guys won't try unless there cars are perfect.
Unless you try , how do you know what perfect is ???
Cheers
Ken
well i think im quite decent in the driving area ... come for a hills run in my current race spec stock as a rock vn and it will show ive got at least guts :D
all i know is i like to drive on the limit and im not afraid to push that little bit harder...... might be a good idea to do this and see how i go
hmm
maybe i could give it a go ...
where could i get some more info regarding the series?
Tom , check with the WASCC as John Hurney is the series co ordinator.( and also WASCC president)
You get to do Wanners,( short and Long), Collie , Wellington dam, Meelup , Mt Brown , Mt Clarence...
If your balls are big , the rewards are good...
Cheers
Ken
( ps , I have small balls and wait to see Tony Flood next year)
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
