  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
hehe i always wanted to be michael andretti :)
but yeah i understand ur point Ken - i say lets find out one day soon :D
Hehe , 21 was when I thought I was invincible..
Was rallying an RX7 and came 5th or 6th in the State Rally championship that year.
Took a MUCH older guy to prove that balls and bravery were no match for age and experience.
Lets just say that after navigating fo the dude I realised that a WA championship win was a distant hope.
btw the dude was Ross Dunkerton and we came 2nd o/r
Cheers
Ken
Ross is a legend in his own right you must look back at that with pride
seriously all this talk has made me wanna find out what i can or cant do in a car ....
ill have to get details asap
31/01/04 is the next training day.
$100 , 12 people for the morning and you get the best (hehehehe, ok , you get me) and if you pass , the mc drift series is your oyster.. :D
Cheers
Ken
nah no thanks im not a drifter not my type of thing
... got anything circuit style going ?
Tom , very expensive running a proper training day at Wanners but will be running for our client base ( that's Hyperdrivems) a late afternoon midweek at the new MC airport venue series where costs are minimal and you get my tuition for a few hours...
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
