  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
lol
yeah fair enuff
but young skywalker i hope your find your path to insurance clear and safe.
for insure you must
or own line you wont
yeah thursday etc is fine. drop an email on progress when you hear about it etc.
if you need any more dodgy insurance advice etc lemme know
