  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
paul i think you should ring Danny .... he seems to know whats wrong with it ... apparently you've put somethin gin the wrong way.... he also said you shouldve marked where the other one was before you took it out so you could pu tthe other one in exactly the same.
that reminds me - time to harrass dad again for my wing .... he keeps ringing pasquali but he fails to get back to him then again when it came to pasquali's fencing dad wouldnt get back to pas either haha.
adrian everytime i go past you .... your all croozy nanna like :D
