haha just reminded me of paul and his Baskin n Robins experience (we walked into a B & R and there were like 12 lesbos in there) and when we come out he goes to me "theres not really any good looking lesbos is there" :rolleyes: its like telling alittle kid there isnt really a Santa .... thats what made me put that comment :)
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
unfortunately i come from a family of women with big hips ..... all got really pretty faces at least .... and my grandma has hardly a wrinkle .... so i guess i could deal with the hips if i look half as good as her at her age!
