  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
oh i dropped my subwoofer on my foot this morning .... trying to reload my car after paul finished hitching up fuel gauge. So day didnt start off well ..... then when i pulled into the carpark at this job i heard a large crunch .... i swear i thought i had cracked my front spoiler on the curb ... i thought this is all i need!! .... all i did was run over a foam cup!! Phew!!
this is just for a day .... in East PErth holding the fort while they go out to xmas party .... here til 5:30 tho no lunch.
I start at the Australian Workers Union around the corner from this place on Tuesday! :) YAY bring on SAFC .... bring on money bakc into my bank ... that goes for a month.
cmon guys .... im stuck here til 5:30 with nothing to do :)
Apparently photocopying room is really cold .... maybe it has ghosts? So its either i whore or i go photocopying ... and i would rather whore.
mmm im eating this thing from MYOB ... it has fruit on top and this yoghurt stuff .... but its more creamier than youghurt .... if you crossed yoghurt with cream this is what you would have ..... soooo yummy
i kinda like my mats tho Alex ...... one sets getting yukky so im going to put the other set in til i get the other set cleaned somehow.
One set was a present :) the other came with the car .... so yeah i wanna be selfish n keep them both ... sorry.
