  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Well im of to wash the GTS .. been parked up now for a couple of weeks now i got my datto ute to drive around in :D coming up to the big city tomorrow and i like my ride looking good :headspin: :headspin: :headspin:
wheres a good place for a counter lunch
thanks Ken Merry Xmas to you too .... wife buy you some new jocks :D
You have a R33 now? ...do tell! Hows the workshop ... been meaning to drop by not liek ive got a whole heap sof things to do at moment!
New jocks ??
Come by tomorrow, we are putting hole in the ground for the dyno and having a bbq and a few beers at lunchtime.
Your sort are always welcome... :)
Cheers
Ken
ps promise I won't try and hit on you but can't spaek for the rest . Hehehe
working on a Saturday? thats disgraceful!! LOL ok i'll come by if you dont mind having a HSV out the front :D
yeah thought the missus wouldve got ya some from xmas .... jocks n socks ... isnt that the way it goes?
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
