  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Well im of to wash the GTS .. been parked up now for a couple of weeks now i got my datto ute to drive around in :D coming up to the big city tomorrow and i like my ride looking good :headspin: :headspin: :headspin:
wheres a good place for a counter lunch
thanks Ken Merry Xmas to you too .... wife buy you some new jocks :D
You have a R33 now? ...do tell! Hows the workshop ... been meaning to drop by not liek ive got a whole heap sof things to do at moment!
New jocks ??
Come by tomorrow, we are putting hole in the ground for the dyno and having a bbq and a few beers at lunchtime.
Your sort are always welcome... :)
Cheers
Ken
ps promise I won't try and hit on you but can't spaek for the rest . Hehehe
working on a Saturday? thats disgraceful!! LOL ok i'll come by if you dont mind having a HSV out the front :D
yeah thought the missus wouldve got ya some from xmas .... jocks n socks ... isnt that the way it goes?
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
