Is that invite universal kenny or just for the girls:bahaha:
I came past today but you guys must have chickened out already...that printer of yours was making a racket rolling around in the boot of my R
Today Micko ??
Mate I always go to a mates place on Boxing day , get in the pool with a few close friends and get well burnt/pissed .
Will be there at 7.30 am tomorrow and come around if you want.
We need someone to barrow the cubic metre of waste concrete :D
Lauren , I don't get jocks from the wife but she now owns 1/3 of a dyno/workshop so I suppose that's her/my present.
What did you get apart from bored ( as in no excitement, not screw..ohh never mind ) :)
Cheers
Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
And as far as the R33 goes, just call me moby , as in whale.. :D
The R is gone and the current budget does not allow for a 4wd replacement so am building an angry R33 GTS-T which used to belong to GTS500 ( aka Danny).
Have a few plans for it and will have some fun dragging/drifting/MCing/SESing .
2wd and 400rwhp should be fun :) :headspin: :headspin: :headspin: :aroused:
Cheers
Ken
lol 7:30??? .... :coffee: :( ..... tell him he's dreaming - a girls gotta have beauty sleep :) 10:30 would be a better estimate :(
i can barrow .... but i wont be wearing a short skirt :)
1/3?? now she's got your balls in a vice :D
$300 worth of bills paid .... $400 for SAFC ... but because of unemployment thats all gone into surviving .... now down to last $200. Makeup um yeah just bits n pieces.
7.30 was for Micko, your 10.30 am will be fine but bring your oktoberfest outfit as promised.
We will be hungry and thirsty by 12...
* Joking Niz , just joking..*
Cheers
Ken
yeah Micko working on replacing it .....
thought Free Willy was better? LOL
thought the one in Danny's doesnt have a motor?
At my age I will even pay for someone , let alone have a free one...
Yep , it's got no moter which will be 1/2 the fun building/sourcing/developing/blowing/redeveloping one for it :D
Cheers
Ken
lol yeah Lumpy said forget the oktoberfest outfit .... nothing would be fine :D
thank god 7:30 was for Micko - dont think my body could handle that kinda shock.
We could always come around and give you a wake up call :)
Cheers
Ken
lol ..... its not a good sight in the morning .... thought Adelaide wouldve proved that :D
Couldn't see you hidden under the doona/wookie hair. hehehee
* sigh , still can't work out why this girl thinks she's ugly/fat/undesirable to the opposite sex :aroused: *
Cheers
Ken
trust me .... i moult more than the wookie. What happens when ya bleach ya hair to buggery.
i dont know .... just me i guess ..... i go thru these really intense up down periods .... at the moment im back down ... im just going insane in this environment :crazy:
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
