We are at a little place in South australia called Streaky bay. Made 2050k in 2 days, not bad i reckon. End of the line is Brisbane but we have a suite booked at crown towers for teh 5th. Should be good i reckon. Killed a bird today, my first roadkill ever :)
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
today was sooo fuuny, i was driving home in the line, and at the lights a P plater pull up next to me is some car and i look and him and smile and they both smile back at me (2 guyz in the car) then one of the guy go shittttt, you must be a good Learner to be driving this car.
when the light turn green i gave it alittle so they heard the loud psssssssssssssss! they pull up night 2 me and go "WOW!!!"
actually you get a lot of attention in the car .... unfortunately by mostly old rough looking guys. and the attention i get in my car is from young little kids .... the most attention i get from my own age group is when im driving a shit box.
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
    • Hello everyone, I am happy to join you.
    • Whereabouts are you, that looks exactly like Akira's old car....
