  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeah - i think its everyone ...aidwins not here .... bams not here ..... :) you dont come on much anymore
Yea , I suppose with Aidwin OS , Bam , who knows and me working hard trying to get a business going and you out of a whoring job the same as Paul then that doesn't leave many others.
Cheers
Ken
:) Ken ..... im sure Lumpy is probably going to lose some weight after all this ;)
good to hear its back together ..... got a lot of mopping up to do tho!
*Wonders if we can get Lauren around to clean ze floor*.
:aroused:
Cheers
Ken
Yea but if it wasn't for cars you wouldn't have met such cool , handsome, witty , entertaining , sexy, charming , knowledgeable , goodlooking, sexy ( oops , already mentioned that ) people like us on this forum.
* thinks , that may be a negative , not a plus... :) *
Cheers
Ken
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
