  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
when it just idle in my driveway (after i take it for a run and i am letting it cool down) i can really smell it :D
* Sigh *
Hi Mike.
As has been told to you by numerous people, get someone to look at it.
The diagnosis points you have given are not descriptive and definitive enough to pinpoint the exact problem ( and why would a qualified person spend hrs on here trying to anyway )
It could be anything from a faulty reg , split hose, leaking injector, filler neck incorrectly fitted ( my guess as I told you before ) , MAYBE running rich, bad plugs, and the wrath of god ( well maybe not the last one )
As has been explained to you before , rather than ask 15 different people at 20 different times , which pisses everybody off cos you get there advice and then ask someone else , go to one person , pay the money and get it sorted.
BTW if you smell fuel is cos it's is unburnt or leaking which is RICH , not LEAN.
And in case you missed the post from 2 nights ago , all ulp cars run black exhausts.
It was the lead that caused the grey colour in the pipe
Cheers
Ken
Ken- its good,im enjoying myself alot with the food and entertainment heheh. But the crazy drivers is another thing, nearly got rammed
yes read paulie's msg
That's good , when you back and are you bringing a swag of GReddy plenums with you for under a grand. lol
Cheers
Ken
    • Did you pay with a credit card? I'd be putting a charge back through then finding a new sparky to sort it out.
    • If you mean the alarm immobiliser; theyre internal to the alarm itself which makes that difficult; I couldnt even see where he put it; its not in the same place as last time; but with all black wiring it might be very challenging to trace  I had someone turn the key for me as I know it only primes for a couple of seconds As my post above; I am getting no voltage to the pump at all; but I am testing continuity of the power line (SB) from the pump plug to the relay fine. As well as the negative from the pump plug to a 12V constant.    Yeah; he blammed the no start on a bad battery; said I needed to get a new battery and it'll start. Turns out the battery drained because the tail lights had been on for half the day during the install (the rubber cushion on the brake switch gave out while he was testing it as I have a picture of the car from that morning with the tail lights off..i've replaced that). The battery was turning over the engine just fine for a long time; but got low since lights were draining it so it was too low to test a start after he finished. I bought a new one on his advice...$250 wasted. My original battery charged up just fine and is healthy.    It was running perfectly fine when I messed up the old alarm (programmed out the remotes). He couldnt start it after removing the old alarm; my assumption is that when he unhooked it; he didnt bridge the circuit back when trying to start it. Its always been perfectly fine. The ECU swap and pump were 2 years ago. It's never missed a beat in that time.
    • This is a big issue for me without the diff. I just have zero drive from the passenger side when drivers side has no traction. Bec's parents place has a crazy steep driveway with odd camber and I have never been able to get up. My bro-in-law's 130i with an (unknown brand) LSD gets up fine as does their dad's Hiace. My car stays at the bottom. We have other odd camber roads around here as we're elevated a bit and if it's raining I can get totally stuck around some hairpins.
    • Yeah, I am super excited for this.
    • Was the car running before he touched the car?
