  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
when it just idle in my driveway (after i take it for a run and i am letting it cool down) i can really smell it :D
* Sigh *
Hi Mike.
As has been told to you by numerous people, get someone to look at it.
The diagnosis points you have given are not descriptive and definitive enough to pinpoint the exact problem ( and why would a qualified person spend hrs on here trying to anyway )
It could be anything from a faulty reg , split hose, leaking injector, filler neck incorrectly fitted ( my guess as I told you before ) , MAYBE running rich, bad plugs, and the wrath of god ( well maybe not the last one )
As has been explained to you before , rather than ask 15 different people at 20 different times , which pisses everybody off cos you get there advice and then ask someone else , go to one person , pay the money and get it sorted.
BTW if you smell fuel is cos it's is unburnt or leaking which is RICH , not LEAN.
And in case you missed the post from 2 nights ago , all ulp cars run black exhausts.
It was the lead that caused the grey colour in the pipe
Cheers
Ken
Ken- its good,im enjoying myself alot with the food and entertainment heheh. But the crazy drivers is another thing, nearly got rammed
yes read paulie's msg
That's good , when you back and are you bringing a swag of GReddy plenums with you for under a grand. lol
Cheers
Ken
    • I downloaded the apps (for windows) and Consult 1 doesn't have this function on it for the Consult 1 plug which I'm pretty sure all Skylines have. You would think someone would have a workaround after 30 years for all Skylines which have ABS.
    • Also, I don't know the actual ABS system on the skylines, but a sneaky thing could be a piece of electronic equipment that makes the ABS think you're moving, and then same piece can send a signal for a locked up tyre... Activate ABS without slamming brakes...
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
